Thread: Jcb's Quad copter Project,
29-03-2013 #29
Im still convinced its a balance thing, i realise you have the same things on each spar but they must be in exactly the same position on each spar, if one of those boards on the side is 5mm out towards the rotor and the opposit one is 5mm towards the center thats a total of 10mm out and although the gyro will compensate to some extent i suspect it would be a little too much and you would be on the limit of your stick all the time with the gyro doing backflips trying to work out what is going on, remember that is still a light craft and the smallest imbalance could make a very big difference.. IMO that is
RickLast edited by Ricardoco; 29-03-2013 at 01:54 PM.
Homemade CNC Project Help
By chaslam07 in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 04-04-2012, 11:53 AM -
RFQ: Small CNC Project
By flipflop in forum Projects, Jobs & RequestsReplies: 1Last Post: 20-09-2011, 10:41 PM -
Project IceMould.
By NC-Joey in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 11-08-2007, 07:00 PM
