Thread: aluminium machining
14-03-2013 #7
Nothing difficult about that - there are various ways to get the bearing bores concentric and machine the bottom face parallel to their axis. It looks like you've chosen 7208 bearings, which are bigger than you need for a 25mm ballscrew - I'd use 7207 instead to reduce the moment of inertia and cost. Have you drawn the rest of it?
Edit: On the rotating ballnut mounts I have made I've tended to make the bearings a light interference fit, but I expect either would be fine. They need to be a sliding fit on the shaft to allow pre-loading.Last edited by Jonathan; 14-03-2013 at 11:35 PM.
machining aluminium with 1.5kW spindle
By routercnc in forum Spindles & Drive MotorsReplies: 13Last Post: 15-02-2014, 02:55 AM -
RFQ: Aluminium frame Machining
By mZeles in forum Projects, Jobs & RequestsReplies: 4Last Post: 27-12-2012, 08:17 PM -
Machining Aluminium
By Steff in forum Metalwork DiscussionReplies: 7Last Post: 14-11-2012, 12:48 PM -
Breaking cutters machining aluminium
By ukpete in forum Tool & Tooling TechnologyReplies: 10Last Post: 16-08-2011, 07:23 AM -
Aluminium passivation - for aluminium to be used outside
By CHudson in forum Metal Finishing TechniquesReplies: 4Last Post: 06-04-2011, 09:18 PM
