Thread: Balls, balls and balls
19-03-2013 #1
Guys I have a 2005 ballnut that i did the proverbial ball dropping trick months ago. I've just gone to put it back together to find that i still have all the balls, problem is one of the orange direction changing plugs is missing? I don't know how as i have not touched it. Can't find it anywhere. Does anybody have spare one going cheap from an old one they can sell me? i don't want to have to buy another nut for the sake of a plug
PaulIf the nagging gets really bad......Get a bigger shed:naughty:
20-03-2013 #2
I think you'll be lucky to find one, unless someone has an empty 2005 nut.
They're a tricky shape, but all the plastic bit does is guide the bearings from one channel, over one to the next... so it shouldn't be that difficult to make something that works. Would be interesting to try it, but probably best to just buy one.
20-03-2013 #3
Ive got that 1610 ballnut with most of the pieces your welcome to parts of that if its of any use. I suspect its entirely different though... being 16mm
20-03-2013 #4
I think i've got an empty 1605 in the shed, dont know if that would work?
.MeLee
20-03-2013 #5
The plastic bits are different sizes, since the channels they interact with are different dimensions...so assorted empty nuts are much help here. I've not got any 2005 nuts since it's rarely the best size screw to use.
20-03-2013 #6
Thanks guys, i have a working 1605 and check, the pitch is the same so maybe close? just hope i don't loose the balls out of that one finding out.
20-03-2013 #7
Ok just gone and had a look and the 1605 i could not risk taking it apart to look. What is interesting is the existing ones in the 20mm nut have 2505/1, 2505/2 embossed on the plugs. I will assume i have number 3 missing. The 2005 also has only 3 plugs and the 1605 has 4.? does it make a difference.
Gary if you are reading this could you shed any light?
Paul
PS
the holes are the same size for the plugs on 16 and 20?Last edited by Swarfing; 20-03-2013 at 07:10 PM.
20-03-2013 #8
did you get them from me?
I have a box of about 50 nuts that need assembling, but are mainly the 1605 and 1610 size. are the ball returns blue or orange?Visit Us: www.automationshop.co.uk
20-03-2013 #9
Hi Gary these are Orange and these came from the over seas shopping arcade i'm afraid ( too good a deal at the time). Do you see any difference between the returns (as long as the pitch is the same) from 16 to 25?
20-03-2013 #10
How come you have so many, do you dismantle them intentionally for cleaning? I've found that a surprising number of the one's I've had from China contain small bits of swarf, which is rather worrying.
Belts or Balls getting me Screwed up! Help I need advice Please.
By longy in forum Belt Drive, Pulleys & TimingReplies: 15Last Post: 15-04-2014, 02:46 PM -
ballnut - balls back in via the side cover and using less balls than original
By dsc in forum Lead Screws, Nuts & SupportsReplies: 9Last Post: 16-11-2013, 04:27 PM -
How to get the balls back in a ballnut?
By Shinobiwan in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 24-03-2013, 04:35 PM -
X2 change balls crews or not?
By Oldie45 in forum Sieg Milling MachinesReplies: 7Last Post: 17-08-2011, 07:55 PM -
Lost my balls!!!
By danielbriggs in forum Lead Screws, Nuts & SupportsReplies: 26Last Post: 19-08-2010, 02:41 PM
