	21-03-2013 #1
	21-03-2013 #2
Hi Tom,
I would paint it all pink first then pick out / fill in / paint the letters with a small brush.
If you need to do a batch of these then i would look at making a set of stencils and a jig, i would still paint them all pink first but having a reverse stencil would mean you could airbrush the letters much faster.
.MeLast edited by Lee Roberts; 21-03-2013 at 11:01 PM. Reason: speeling
	21-03-2013 #4
hi Rick i mean engraved in the mdf as i say the letters are about 15-20 high and about 3mm wide and 2mm deep
	22-03-2013 #5
paint in the letters first, when dry use a gloss paint roller with little paint on it and roll over the top with very light roller motion, do as many coats to look good
	22-03-2013 #6
Best to paint the mdf before you engrave it as then when you fill in the black it will not bleed into the pink!
If you use a resin paint you could fill the 2mm up with the black.
Peter
	22-03-2013 #7
I think standard procedures for painting text like this is to use a syringe, needle and ink to fill the letter 'pockets'. Mind you this is on metal, so in your case I would paint the piece with waterproof paint to stop the ink sinking into the MDF and when everything is dry, use the ink method.
Regards,
dsc.
	22-03-2013 #8
Don't know about infilling letters with ink but it was certainly done infilling the letters with paint, normally something like "One Shot" which is a traditional signwritting paint. Once the piece had dried it was then buffed & polished to ensure that it was flat & any high spots in the paint were removed.
MDF is porous so I would think it would need to be sealed in some way before any painting.
	22-03-2013 #9
thanks to everyone who replayed to me i have ago and see the best way to do this and let you know which way is best
	26-03-2013 #10
Hey fella, just spotted this video it's towards the end that will give you an idea how to do it. But I found the whole video very interesting.... http://blog.ponoko.com/2011/05/27/br...ecause-we-can/
The Following User Says Thank You to D-man For This Useful Post:
RFQ: 50x Small machined, anodised, engraved plates
By Husky in forum Projects, Jobs & RequestsReplies: 1Last Post: 10-03-2013, 12:18 AM -
RFQ: Shot blasting or other paint removal
By craigrobbo in forum Projects, Jobs & RequestsReplies: 14Last Post: 01-02-2013, 12:21 AM -
Can you identify this paint on metal finish..?
By Wal in forum Metalwork DiscussionReplies: 2Last Post: 29-01-2013, 06:25 PM -
Powder coat & paint
By craigrobbo in forum Metal Finishing TechniquesReplies: 6Last Post: 06-08-2012, 09:06 PM -
Design and machining raised letters
By compfranon in forum CAD & CAM SoftwareReplies: 20Last Post: 11-09-2010, 10:59 PM
