    Spindle motor?, does the spindle run freely?, in which case it's likely either the motor, the controller card, or a short in the cables that run between. Not very informative, I know, but it needs diagnostics to determine any further.
    A bit of history - I converted my SX2.7 to CNC, but when I first bought it it ran for <5 mins then died completely. Repaired under warranty by Arc Eurotrade - brilliant service and they had the kit to diagnose motor and controller (had to return both to them for this). Might be worth a call to see if they're prepare to help out - but it'll cost! Also, they stock the replacement motors and controllers....again, it'll cost.
    Once I'd converted to CNC I was trying to reverse-engineer the controller card and ended up blowing it up a second time. At this point I realised replacing the controller and motor with something that suited my purpose better was as cost effective as replacing the controller card alone. You might want to think out of the box to replace rather than repair.
    Uzzy's Avatar
    Lives in Chatham, United Kingdom. Last Activity: 16-11-2021 Has been a member for 3-4 years. Has a total post count of 2.
    Doddy,
    Yes spindle runs freely, I just need someone to service it and advise whats wrong and cost of repair :-)
    I'd replace it with an AC servo (if your X2 is belt driven) and get a new motor pulley to suit.
    https://www.aliexpress.com/item/3304...16109932%22%7D
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. Replies: 2
  3. Help and Advice sought about new motor for my mill
    By alanb in forum Milling Machines, Builds & Conversions
    Last Post: 26-01-2012, 08:04 PM
  4. Motor problem
    By irving2008 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2009, 01:06 AM
  5. Motor / drive wiring problem: help!
    By lateAtNight in forum General Electronics
    Last Post: 29-04-2009, 07:40 PM
