    Asto i just checked out those sites that sell obsolete parts.
  2. Asto
    looks like that's a digiplan proprietary part number, common anti-copy practice in those days. given the age & specs of the driver i'd suggest 3 options:
    1. trace the circuit to determine if npn or pnp then given the spec of the driver (2.5A, 24v IIRC) choose something appropriate in a modern transistor (6 - 10A Ice-max, Vce 100v+, which is likely to be better anyway on Vce-sat and hfe specs). TBH, given other things have may have died I'd not bother.
    2. buy a replacement driver off ebay (or check if members such as JohnS have some left over from upgrades)
    3. use this as opportunity to upgrade to modern drivers
    asto's Avatar
    Lives in Attica, Greece. Last Activity: 1 Week Ago Has a total post count of 68. Received thanks 1 times, giving thanks to others 0 times.
    Asto
    It seems I do not have choices here. So I better follow your advise irving but for upgrading I do not have a plan yet. And I think I know of at least one way to test this part off the pcb and see if it is a PNP or NPN.
    Thanks.
    cheers
    Just a stab?
    TIP32C-PKS
    TIP32C-PKS - SEMILAB - Ashlea Components
    PS
    Just noticed their telephone number is a Swindon one?
    Just checked, don't have any of these drives but do have a sack bag of stuff from a couple of Denford Starmill conversions, Need to get these on Ebay.
    Also have the guts from a Roland PNC - 3100 and a Roland PNC - 2200
    John S -
    i2i's Avatar
    Hi Asto, i'm a bit confused here. The first picture you posted shows a parker sd2 drive, but the second picture showing the component is of a parker cd20 drive.
    Is the lathe an Easiturn, if so the drive should be a cd20, and to have an led showing it would seem the drive is a cd20 rather than a sd2.
    asto's Avatar
    Quote Originally Posted by Swarfing View Post
    Just a stab?
    TIP32C-PKS
    PS
    You know Swarfing, that was a hit.
    This morning I attached three wires on the board in place of removed transistor and at the other end a triple female socket. Then started playing with several types of transistors that I'd found handy and guess what... The one that made the SD2 play music again was the TIP145. So the TIP32-C is the closest equivalent as its collector current is 3Amps while the TIP145 is Ic=10Amps.
    I think the supplier's location is...518, Purley Way, Croydon, CR0 4RE
    Conclusion...Very few things may remain unidentified in this forum.
    I am glad I've joined.
    Thanks!
    Ps. I wish to thank Irving as well for helping me to narrow my search_Sorry for any syntax errors.
    asto's Avatar
    Well... i2i,
    I only have machines driven by SD2's. So, both pictures are from the SD2 drive. What you see in the 2nd image is the component side of the PCB which is visible_ copper side_(well that's o.k double sided board) in the first photo.
    cheers
    asto's Avatar
    Thanks John S!
    i2i's Avatar
    Quote Originally Posted by asto View Post
    Well... i2i,
    cheers
    that is a wierd one then, as i have an sd2 and a cd20 in front of me and the second pic looks exactly like the cd20. But not to worry, i'm glad you've identified the component. I spoke to parker today regarding a schematic, and they put me onto a company that may be able to help.
  1. Denford digiplan 300 drivers, i cant get them to run on mach 3
    By scnc in forum Motor Drivers & Controllers
    Last Post: 30-04-2014, 09:56 PM
  2. Replies: 1
  3. eBay: Denford Triac Parker Digiplan SD2 & SD3 Stepper Drivers
    By davidimurray in forum Items On eBay UK
    Last Post: 25-02-2013, 10:23 PM
  4. Digiplan parts left from "upgrade"
    By black5f in forum Motor Drivers & Controllers
    Last Post: 17-03-2011, 12:02 AM
  5. Parker Digiplan schematics
    By GT390 in forum General Electronics
    Last Post: 01-01-2011, 03:52 PM
