    Use the Stepconf Wizard, it's just a case of inserting the appropriate numbers. The main ones to get right are the step count (i.e. 800 steps if your drives are set to 800 steps on the dip switches) and the parallel port pin numbers.
    As a heads up, have you ran the latency test yet? Because LinuxCNC uses a realtime kernel, it can be a bit fussy on hardware. Onboard graphics and WiFi cards are the main culprits. If you really need to use a wifi card, there's a possible solution (for geeks!) HERE.
    I think the main problem for me is the whole new dictionary of phrases etc that mean very little to me at the moment. The learning curve seemed more of a wall, I was hoping that someone had scaled it before ...
    I know I will have to get to grips the all the terms and phrases very soon, I guess I was being a little impatient to see some computer generated movement on the stepper..
    I'll take the time to read the documentation I have and work through it slowly - but understanding each bit.
    On the subject of the latency test, yes I have run it, for about 3 hours, the first 10 minutes REALLY abusing it and I got a bunch of numbers... That I noted down... but so far I have not seen a button to press to transfer them to somewhere to store (as I would expect) nor a field into which I should input them.. I guess I have missed something along the way and will have to revisit the wizard.
    Watch this space, I'll post my progress so anyone following me may have a "cheat sheet" to get going quickly.
    Danny
    This is a good place to start: LinuxCNC Documentation - HTML version
    And in particular, this: Stepper Quickstart
    Cheers Birchy
    I found it yesterday and spent much of the day reading it.
    I've not done the stepper quick start yet but I have discovered where I went wrong AND the docs I needed for the pin assignments. So a huge step forward.!
    I'll be reading the quick start docs a few seconds after hitting the "Post Quick Reply" button here
    cheers
    Danny
    At the end of the day, it's just a new piece of software and will take some time to get familiar with. It's no different to using Mach or Autocad or some other "technical" application, but we're always keen to get motors spinning and cut corners which isn't a wise thing to do.
    Glad you're progressing. I find the LinuxCNC forums are very friendly and helpful.
    Hi guys
    I finally managed to get some time to play and have got as far as I can.
    I have a downloaded document from Zapp for the BOB that has the pin assignments as below. (The document is called "ZP5A-INT axis interface board manual.pdf")
    This is what I have set up on the LinuxCNC.
    I'm unsure of pin 1 (there is no "enabled"), pin 9 (no "spindle motor" - is this the spindle for a router?), pin 4 & 17 (no "B" option - would "B" appear if I set it for a 5 axis board?),
    WRT the second table, is that for use with the "joystick" type manual control - a totally separate connector?
    Any advice\pointers greatly received.
    Danny
ID:	8693   Click image for larger version.
    Are you running two motors on 'X' if you are change 'A' settings to show 'X' (two motors for X running on different pins). Turn all those limit pins off for now, Spindle on is for the relay connection. Section 2 is for separate hand controller you can get for these boards.using four motors still only means a 3 axis machine.
  1. Problem with Zapp Automation website
    By Shinobiwan in forum Marketplace Discussion
    Last Post: 26-05-2014, 09:26 AM
  2. Zapp 3-Axis kit - putting it all together
    By birchy in forum Motor Drivers & Controllers
    Last Post: 18-02-2013, 12:05 PM
  3. Zapp Automation CNC Driver Kit 4 Axis
    By whensparksfly in forum Motor Drivers & Controllers
    Last Post: 01-03-2012, 01:54 PM
  4. 10% Discount weekend At Zapp Automation
    By Gary in forum Marketplace Discussion
    Last Post: 19-02-2012, 12:42 PM
  5. Zapp Automation Discount Weekend !
    By Gary in forum Manufacturer News
    Last Post: 21-08-2011, 11:29 PM
