15-05-2013 #18
Had another look at the weekend & still have a problem with the plugin tripping mach3 as soon as I try to start the spindle.
The other plugin that is on the mach3 forum is a bit strange as well. If I start mach3 from scratch & press the spindle start there is a click & the button flashes yellow but the spindle doesn't start. If I load some gcode & run it the spindle starts, runs & stops as it should. If I then try pressing the spindle start button again the spindle starts & I can also change the speed, pressing the button again stops the spindle as it should, can do that all day long until I shut mach3 down. When I start it up again we are back to not being able to start the spindle until I have run some code.
Not really a problem as it seems to work ok when cutting anything but just seems a bit strange.
Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
By Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM -
Mach3 ports and pin setup to match my control box
By Sparky in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 13-11-2014, 04:00 PM -
can mach3 burnout transistors on a CNC control board?
By kevinb in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 29-11-2010, 04:24 AM -
HID interface for remote control of Mach3
By Smiler in forum Electronic Project BuildingReplies: 0Last Post: 10-05-2009, 12:59 PM
