    I would go for a trap (square) type thread, threaded rod at that size would strip the nut very quickly regardless of the calcs.
    You can try the 'column strength calculator' from Nook
    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    I thought of using trapezoidal screw at the beginning, but I couldn't find anything with a fine enough pitch. M12 standard thread fine pitch is 1.25, smallest I could find in ACME screws is 1.5.
    I'll try Nook, when they fix their website:) (seems to be down at the moment).
    Regards,
    dsc.
  1. balscrews from linear motion bearing and rails, question about sizing
    By Boyan Silyavski in forum Lead Screws, Nuts & Supports
    Last Post: 18-08-2013, 08:11 PM
  2. quick question about lead screw
    By japcarmaniac in forum Gantry/Router Machines & Building
    Last Post: 09-02-2013, 11:25 PM
  3. FK12 BEARING, tighten on lead screw first - newbie question?.
    By Mark Snape in forum Lead Screws, Nuts & Supports
    Last Post: 08-03-2012, 10:59 AM
  4. one lead screw or two
    By johngoodrich in forum Gantry/Router Machines & Building
    Last Post: 13-08-2011, 02:39 PM
  5. x-axis rails and lead screw
    By adambrum in forum Gantry/Router Machines & Building
    Last Post: 13-08-2011, 01:56 PM
