Machine building in living room, second machine being planned before the first is finished. It seems to me you are a natural for this site. Well done. G.
The Following User Says Thank You to GEOFFREY For This Useful Post:
31-03-2013 #2
Sure is
I must remember to shift that milling table out of the Utility room before the kids trip over it .....lol!If the nagging gets really bad......Get a bigger shed:naughty:
The Following User Says Thank You to Swarfing For This Useful Post:
01-04-2013 #3
Welcome to the forum, if you still need to buy a power supply for those drivers then as Jonathan has said you would be better off with a higher voltage, think those will run up to 50v unless your buying a second power supply because the one you have won't be enough for all the motors.
Have a read through some of the build logs before you start buying new parts for the next build, it will give you a good idea of what will suit your needs best for the new machine.
Best of luck with it.
The Following User Says Thank You to martin54 For This Useful Post:
NEW MEMBER: New to this forum, bristol
By roygbiv in forum New Member IntroductionsReplies: 3Last Post: 08-01-2011, 04:01 PM -
NEW MEMBER: Hello all!!, Bristol England
By Danimal in forum New Member IntroductionsReplies: 1Last Post: 10-09-2010, 09:31 PM -
NEW MEMBER: hello everybody, Bristol
By HypnoToad in forum New Member IntroductionsReplies: 3Last Post: 09-09-2010, 12:11 AM -
NEW MEMBER: Hello from Bristol
By matthewh101 in forum New Member IntroductionsReplies: 9Last Post: 10-11-2008, 12:13 AM -
NEW MEMBER: New Member - Bristol UK
By spyder.boy in forum New Member IntroductionsReplies: 1Last Post: 05-10-2007, 09:33 AM
