    dudz's Avatar
    Lives in Dunedin, New Zealand. Last Activity: 1 Week Ago Has a total post count of 295. Received thanks 2 times, giving thanks to others 79 times.
    Looking for a used set of these ; 01 Pro Tram Bridgeport Head Square Knee Mill Spindle CNC Router milling endmill | eBay
    To square my spindle against my cutting table.
    Swedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne with Heidenhein TNC155A controller.
    Just use one normal dial indicator. If you mount it on an arm, which can just be a bent piece of steel bar, you can take measurements at 4 points (i.e. 12:00, 3:00, 6:00 and 9:00 on the clock) and compare them to find how far out the spindle is in each axis. That tool is just a gimmick to make it slightly faster.
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    dudz's Avatar
    Thanks Johnathon. If you could post a pic for ref, it would help me. I am new to all this, so still a learning curve. Where do I get a dial indicator and which one ?.
  5. #4
    Here:
    Squaring a Drill Press Table
    For the indicator you don't need anything special, just get a cheap one:
    dial indicator | eBay
    If you get one on a stand you'll find it useful for other things, like checking backlash and spindle runout.
  6. #5
    dudz's Avatar
    Then this one ? Toolzone Metric Dial Test Indicator DTI & Magnetic Base | eBay
    Just seen the post costs to France 24.99 LOL
    Just an example
  7. #6
    That would be fine.
  1. Making the frame square
    By cropwell in forum Gantry/Router Machines & Building
    Last Post: 08-03-2014, 11:00 PM
  2. engineers square - recommendations
    By dsc in forum Marketplace Discussion
    Last Post: 09-06-2013, 08:13 PM
  3. Square Ballnut??
    By Ricardoco in forum Gantry/Router Machines & Building
    Last Post: 29-06-2012, 10:32 PM
  4. Getting everything square
    By daveshorts in forum Gantry/Router Machines & Building
    Last Post: 31-01-2010, 11:21 AM
  5. Colchester Student 1800 Square Head Lathe - HELP !
    By cncroger in forum Milling Machines, Builds & Conversions
    Last Post: 03-02-2008, 08:28 PM
