Page 6 of 13 FirstFirst ... 45678 ... LastLast
  1. #51
    Quote Originally Posted by Carlb1058 View Post
    Just a tad - cheers :) I ended up with 409.62 using 3.175 as the tool diameter
    Once we have got both axis to move the same amount i can do the math again and give you the imperial equiv, then we can change the system to old school as like swarfing said it could be a yank model. but we will get it for you then of course that will rule out the mechanical and software stuff as the source of your trouble, leaving only the electrics but they may be fine and just need proper BOB and stepper drivers should you be so inclined..
    Rick
  2. #52
    Yep 3 to a cm the biggest problem with trying to measure the X is it is fully enclosed and I'd pretty much have to tear it apart to get to it but I shall attempt to get a close as damn first :)
    Dont bother it can be worked out with the software al be it a little long winded..
    Rick
  3. #53
    well that was easier than expected, managed to get a 1cm wide flat file between the frame work and as near as damn the X is 3 turns as is the Z, so all the screws are the same size
    Carl
    Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
    La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
  4. #54
    confused but could be possible?
    7.26TPI 0.13774" 3.499mm pitch is about as close as you could get to that. Stick with tuning it out for now like Rick said before. Imperial or not you would still like it working with what you have. Sorry i took this away from that.
  5. #55
    Quote Originally Posted by Swarfing View Post
    No drama, it's always good to learn new stuff :)
    Carl
  6. #56
    Got to hit the sack, hope get somewhere soon
    Paul
  7. The Following User Says Thank You to Swarfing For This Useful Post:
  8. #57
    Paul
    Lightweight...LOL
    Rick
    NN mate
  9. #58
    Lightweight...LOL
    Rick
    NN mate
    Looks like im a lightweight too Im off to bed as well, speak tomorrow Carl
    Rick
  10. The Following User Says Thank You to Ricardoco For This Useful Post:
  11. #59
    Rick
    no problems - all the help so far has been great
    Carl
  12. #60
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 18 Hours Ago Has been a member for 9-10 years. Has a total post count of 300. Received thanks 28 times, giving thanks to others 13 times.
    Why not get Mach to do the work for you ? go into "Settings tab", just above the reset button "set steps per unit" start with X enter 100 measure how far it moved then tell it how far it moved and will set steps up for you.
    Do the same for all axis do a test cut if not correct go though it again.
    Phill
  1. Yet another Chinese 3020 CNC upgrade thread!
    By Pointy in forum Machine Discussion
    Last Post: 18-02-2014, 01:04 PM
  2. A decent little (PCB miilling) Chinese machine...
    Last Post: 18-06-2013, 06:59 PM
  3. Chinese CNC machine modifications - Discussion
    By craigrobbo in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2012, 06:51 PM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. Chinese CNC machine...whatchathink?
    By HankMcSpank in forum Chinese Machines
    Last Post: 11-04-2011, 05:21 PM
