Thread: Upgrade? Chinese CNC Machine
Y now equals 80mm on 20 turns and I've got one bent allen key
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
04-04-2013 #2Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
04-04-2013 #3
Rick,
Yep gettin' there, just uninstalled, rebooted, re-installed, rebooted, re-setup Mach3, rebooted, loaded the g-code for the 100mm X line and the 100mm Y line and get 102mm on both. . .
used stock settings of 400 steps, 2000 velo, 200 accel for both X&Y, Z is 400s, 700v, 100aLast edited by Carlb1058; 04-04-2013 at 01:51 AM.
Carl
04-04-2013 #4Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
04-04-2013 #5Cheers
Carl
04-04-2013 #6
The eBay listing indicates he has 4mm pitch screws and 20 turns moved it 80mm, which also indicates 4mm pitch screws as 80/20=4mm. So nothing to worry about.
The voltage readings are strange - should have got 5V or 0V, but nevermind as we now know they're set to 1/4 microstepping.
04-04-2013 #7
I didn't get anywhere near 5v, the readings I got were after atleast a dozen tests the first few were around the 2.7 - 3.2 range and they slowly dropped until they stayed pretty static at 2.2 - all three chips did exactly the same thing.
I wonder if it's worth just throwing an extra 90 bux at it for a board with dip switches etc?Last edited by Carlb1058; 04-04-2013 at 10:04 PM.
Carl
04-04-2013 #8
NO.
If you are going to throw money at it get the separate drives.
More reliable and if one goes down you can replace it, if one of those Toshiba boards goes down the whole lot is toast.John S -
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
