Thread: Upgrade? Chinese CNC Machine
02-04-2013 #21
Rick,
Been toying with the steps and velo etc - getting close but still get it ovalling (if that's a word) on the Y instead of a circle, that is my vernier is showing me right dimensions for a 52mm circle on the X but narrower on the Y - might knock it down some more and see what that does.
As for Driver Test, yep ran that and it's fine, the machine is a not so old PC that was fresh installed with XP SP2 and Mach3 - nothing else on there - not even a virus checker seeing as it's not net connected it's not needed.
I use Aspire 3 on a different machine to create what I want
Addon bit:
As you can see, it's not a circle??? oh and I started videoin' as an afterthoughtLast edited by Carlb1058; 02-04-2013 at 04:49 AM. Reason: Forgot summut - Now added Video
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
02-04-2013 #22
If you have been playing about with the steps does in now move the correct distance in each direction? Have you tried just moving an inch or two in a straight line in each direction doing each axis separately? Did you remember to hit save on the motor set up after you had changed the steps on each axis, simple thing but easy to forget to do when things aren't going as planned lol.
02-04-2013 #23
Ok thats better than you had before, so that means we are in the right track, i wonder if both the ballscrew are the same. could you do me a favour and cut a strait line 100mm long on the X and 100mm long on the Y and then measure them and let us know what you get.. Just Like Martin suggested.
RickLast edited by Ricardoco; 02-04-2013 at 10:44 AM.
The Following User Says Thank You to Ricardoco For This Useful Post:
02-04-2013 #24
100mm on the Y I get 52mm
100mm on the X I get 42mmCheers
Carl
02-04-2013 #25
02-04-2013 #26Cheers
Carl
02-04-2013 #27
02-04-2013 #28
Change X from 200 to 384.6
Change Y from 200 to 476.2
Steps per that is
Then try running 100 mm in X and YLast edited by John S; 02-04-2013 at 11:46 PM.
02-04-2013 #29
02-04-2013 #30
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
