Page 4 of 13 FirstFirst ... 23456 ... LastLast
  1. #31
    LOL my brain has been doing loops here.. What size cutter are you using..
    Rick
    20 deg - 0.5F - 3.175 diameter coz that's what was in it when I wandered out to the shed this morning :)
    Onwards and upwards to try these new figures - digits x'ed
    Carl
    Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
    La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
  2. #32
    Quote Originally Posted by Carlb1058 View Post
    97 on the X 86 on the Y or so my vernier says
    Carl
  3. #33
    so your cutter is a 3mm cutter?
  4. #34
    ok Try this
    X 408.1
    Y 512.8
    with the same cutter of course
    Rick
  5. #35
    ok Try this
    X 408.1
    Y 512.8
    Rick
    100 on the Y 105 on the X - I know this'll all go way over my head but how do work it out?
    Carl
  6. #36
    Surely that is an 1/8" cutter?
  7. #37
    Ok divide 200 ~ (the 'steps-per' that is set on the axis in motor tuning) by the cut measurement minus the cutter measurement(Dia 3mm as the software is running in metric mode 0r 1/8" if you require brain drain ), and then multiply by the measurement you told it to cut which was 100mm..
    Rick
  8. #38
    Quote Originally Posted by Swarfing View Post
    It may well be.
  9. #39
    Are we actually sure these are metric screws? did they kick you a machine built for our American cousins and give you one with imperial screws?
  10. #40
    Im not sure what they are but something is not right but then when its cutting a circle we can get him to look a bit deeper into it.. I do however suspect you may be correct at least in some part..
    Rick
  1. Yet another Chinese 3020 CNC upgrade thread!
    By Pointy in forum Machine Discussion
    Last Post: 18-02-2014, 01:04 PM
  2. A decent little (PCB miilling) Chinese machine...
    Last Post: 18-06-2013, 06:59 PM
  3. Chinese CNC machine modifications - Discussion
    By craigrobbo in forum Milling Machines, Builds & Conversions
    Last Post: 14-05-2012, 06:51 PM
  4. Electronics upgrade for an existing machine.
    By Shinobiwan in forum Electronic Project Building
    Last Post: 18-03-2012, 04:01 PM
  5. Chinese CNC machine...whatchathink?
    By HankMcSpank in forum Chinese Machines
    Last Post: 11-04-2011, 05:21 PM
