Thread: Upgrade? Chinese CNC Machine
Ok divide 200 ~ (the 'steps-per' that is set on the axis in motor tuning) by the cut measurement minus the cutter measurement(Dia 3mm as the software is running in metric mode 0r 1/8" if you require brain drain ), and then multiply by the measurement you told it to cut which was 100mm..
RickLast edited by Ricardoco; 03-04-2013 at 01:12 AM.
03-04-2013 #2Cheers
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
03-04-2013 #3
Carl measure the pitch of the leadscrews
03-04-2013 #4
03-04-2013 #5
Agreed......
03-04-2013 #6
Carl
03-04-2013 #7
03-04-2013 #8Cheers
Carl
03-04-2013 #9Always bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
03-04-2013 #10Cheers
Carl
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
methinks I did summut wrong
