Thread: Upgrade? Chinese CNC Machine
The Following User Says Thank You to Ricardoco For This Useful Post:
03-04-2013 #2Cheers
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
03-04-2013 #3
Why not get Mach to do the work for you ? go into "Settings tab", just above the reset button "set steps per unit" start with X enter 100 measure how far it moved then tell it how far it moved and will set steps up for you.
Do the same for all axis do a test cut if not correct go though it again.
Phill
03-04-2013 #4
03-04-2013 #5
I dislike just scaling the step/mm values to make it work as it can mask more fundamental issues, and generally isn't as accurate. You should be able to measure the ballscrew pitch and work it out. The comment earlier saying the 'the Y however seemed to jerk' implies it could be stalling as the motion should be very smooth. If that is the case you need to find what's causing that, else the distance readings for that axis are meaningless.
Instead of just measuring a small distance along the screw, measure say 20 turns and divide the result by 20. Assuming you can access the motors, you shouldn't have to dismantle anything. Just measure the distance between the axis and a convenient point, turn it 'n' times by hand and measure the distance again. Divide the difference between those distances by 'n' and you have the pitch. If you've got a digital caliper then measure it over about 150mm to get the most accurate reading.
Doing a test cut is not the best way either, since spindle runout and tool deflection can introduce small errors and it's not possible to measure in wood that accurately anyway. Instead measure how far the axis moves. Measuring the distance between two parallel lines would be easier, and a bit more accurate, than measuring the length of the line, since you're measuring between straight edges not arcs.
Assuming the '3 turns per cm', i.e. 3.3mm pitch is reasonably accurate, the step/mm values we've ended up with don't make much sense. The motors are run from TB6560 ICs, which only support microstepping settings which are powers of 2 up to 2^4 (16). Assuming (as there's a slight chance it may not be) the motors full step resolution is 200 step/rev, that means your motors can be set to 200*2^n where 0<n<4. We need to find steps per mm, so divide by the pitch-> 200*2^n/3.3 = 60.6*2^n, where 0<n<4. That means the correct step/mm value could be one of the following (rounded to 2DP); 60.61, 121.21, 242.42, 484.85, 969.70. None of those seem anywhere near the 408.1 and 512.8 you tried... so I reckon there's something else causing problems here.
You could measure the voltages at the M1 and M2 pins of the TB6560 ICs on your driver board to determine what the microstep setting actually is. The datasheet here shows which pins to probe.Last edited by Jonathan; 03-04-2013 at 12:16 PM.
03-04-2013 #6
Hi Jonathan, this was initially to find out if it was an electrical or a mechanical problem, or indeed both, as i understand it there is no way to change the steps on the drivers that could be discovered. So Im glad you are here to cast your eye over it, we also dont know if the screws are metric or imperial although the chap has said they all measure the same..
RickAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
03-04-2013 #7
Hi Jonathan,
Clarification on the following please:
1) measure the distance between the axis and a convenient point
Tipping the machine over gives me clear access to the Y screw, both X & Z have a lot of body work around them which seriously limits any access - so with that said, please define axis and convenient point, don't forget you're talking to a total newbie here, the only machines we had in school were a bench drill and lathe - damn, calculators didn't even surface until years after I left!!
2) measure the voltages at the M1 and M2 pins
All I have in regards to voltage measurement gear is a simple multimeter that I use for checking the wiring on the Meriden and my FLH will this suffice?Cheers
Carl
03-04-2013 #8
Measure how far the axis moves. So for example on X move the gantry to one end, then turn 20 turns (or whatever) and measure how far it moved. You don't need access to the screw.
The meter you have will be fine. Just connect the negative probe to negative, (i.e. ground) and the other one to the correct pins. You may have to unscrew the board to access one of them.
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
