Thread: Upgrade? Chinese CNC Machine
dislike just scaling the step/mm values to make it work as it can mask more fundamental issues, and generally isn't as accurate. You should be able to measure the ballscrew pitch and work it out. The comment earlier saying the 'the Y however seemed to jerk' implies it could be stalling as the motion should be very smooth. If that is the case you need to find what's causing that, else the distance readings for that axis are meaningless.
This is pretty much what I was going to do with the gerber when the time came so how would I go about setting that up? It's belt driven via gearing rather than being a ballscrew.
Yet another Chinese 3020 CNC upgrade thread!
By Pointy in forum Machine DiscussionReplies: 31Last Post: 18-02-2014, 01:04 PM -
A decent little (PCB miilling) Chinese machine...
By HankMcSpank in forum Machine DiscussionReplies: 5Last Post: 18-06-2013, 06:59 PM -
Chinese CNC machine modifications - Discussion
By craigrobbo in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-05-2012, 06:51 PM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM -
Chinese CNC machine...whatchathink?
By HankMcSpank in forum Chinese MachinesReplies: 21Last Post: 11-04-2011, 05:21 PM
