Thread: Mach3 / cambam
Ah great Thanks.
Now I have set feed/plunge rates. How do I get Z to drop faster to just above the material then slow down to the plunge rate ? It seems to take forever just to drop near the materialSwedish Storbro Luna - 3 axis CNC mIll - 250 - 2500rpm / 1.1 tonne
01-04-2013 #2
Sorry Dudz, got a copy of Cambam but not familiar with it, tend to use VCarve pro for speed
John S -
01-04-2013 #3
Is V carve pro worth the money ? Always thought it was a bit exp
01-04-2013 #4
Depends on your work.
VCP is more for wood workers and engraving / sign work but it's very easy and low learning curve. Tends to put tool paths out that dance about a lot and waste a bit of time. However you more than save that time in programming.
If you have to make say 500 off an item then it better to spend more time programming and save cutting time.
I tend to use Dolphin for engineering jobs and VCP for what i call simple or arty farty jobs.John S -
Setting rapids in CamBam
By swisscheese in forum CAD & CAM SoftwareReplies: 4Last Post: 04-04-2014, 02:30 PM -
Hobby-CNC Workflow - SKETCHUP + CAMBAM + MACH3
By WandrinAndy in forum Computer SoftwareReplies: 23Last Post: 04-10-2013, 02:53 PM -
Cambam / milling Alu
By dudz in forum CAD & CAM SoftwareReplies: 5Last Post: 23-12-2012, 05:22 PM -
Drilling Acrylic with CamBam
By m.marino in forum Machine DiscussionReplies: 2Last Post: 06-06-2012, 04:45 PM -
How do i make this in cambam?
By motoxy in forum CAD & CAM SoftwareReplies: 4Last Post: 09-02-2012, 06:01 PM
