    If it wires 230 - 240v delta then just wack a vfd on it and away you go :-)
    Quote Originally Posted by Swarfing View Post
    How can I tell? motor plate says 440v and there isnt the normal terminal box for changing star or dlta configurations. will a 440v motor run on 240v not be half as slow?
    Nice to see you back Ross, was reading some of your threads the other day and said to myself "i wonder what hes upto these days".
    .Me
    If there is no obvious opening or cap to reconfigure then maybe not? google mot or details and see what comes up.
    I think you probably can still reconfigure it , but you will need to find the star point on the windings and the rewire as delta. G.
    Lives in East Lothian, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Whether the motor can be altered to run on 240V depends on if it's wired as Star or Delta 440V.
    It's a case of carefully dismantling the motor, and seeing where and how the coils are connected. If all the coil wires ultimately end up with 3 going to the power feed, and 3 joined together in at one point, it can be changed to run on 240V. However, if each of the three going in split to two, then it's already in delta and can't be changed.
  7. The Following User Says Thank You to m_c For This Useful Post:
  8. #7
    Absolutely correct m_c, I assumed the motor is probably wired as star which is why I said it can "probably" be reconfigured to delta. If it is already delta then there is no "simple" solution. G.
  9. #8
    Thanks I was going to ask Geoffrey to elaborate but it think thats clear enough now. I'll have to check but I think the motor plate has a triangle on it so already delta. I've found a bit more info and it looks like the wiring is all done in the base. I'll have a proper look tomorrow.
    A bit more research has also highlighted the weakness of the plastic gears so even if I can find replacements then it looks like a maintainance problem. belt drive might be worth the work.
    Thanks for the info. good to know all the options
  10. #9
    Thanks Lee, good to be back. Been converting a barn for the last 3 years and still not quite finished but need some down time to try and keep me sane.
    Progress will be slow but I have a lot planned for this mill, essentially it will be full cnc but with a Arduino (or similar micro processor) to monitor speed, axis DRO and act as a standalone controller for quick manual use.
  1. CONVERSION: EMCO Compact 5 CNC Conversion
    By sid8ball in forum Conversion Build Logs
    Last Post: 10-10-2019, 11:51 AM
  2. FOR SALE: Emco mill 50 cnc mill like Denford Triac
  3. Emco conversion help needed
    By Ecu-master in forum Milling Machines, Builds & Conversions
    Last Post: 29-03-2014, 10:33 PM
  4. Emco mill 50 Y axis travel?
    By gavztheouch in forum Emco Milling Machines
    Last Post: 01-03-2014, 11:10 AM
  5. Emco Compact 5 Conversion
    By Pete92 in forum Emco Lathes
    Last Post: 01-10-2013, 11:31 PM
