Thread: Emco Mentor Mill conversion
02-04-2013 #34
Thanks I was going to ask Geoffrey to elaborate but it think thats clear enough now. I'll have to check but I think the motor plate has a triangle on it so already delta. I've found a bit more info and it looks like the wiring is all done in the base. I'll have a proper look tomorrow.
A bit more research has also highlighted the weakness of the plastic gears so even if I can find replacements then it looks like a maintainance problem. belt drive might be worth the work.
Thanks for the info. good to know all the optionsLast edited by Ross77; 02-04-2013 at 11:52 PM. Reason: spelling
CONVERSION: EMCO Compact 5 CNC Conversion
By sid8ball in forum Conversion Build LogsReplies: 1Last Post: 10-10-2019, 11:51 AM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
Emco conversion help needed
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 29-03-2014, 10:33 PM -
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
Emco Compact 5 Conversion
By Pete92 in forum Emco LathesReplies: 7Last Post: 01-10-2013, 11:31 PM
