Thread: Emco Mentor Mill conversion
05-04-2013 #18
Stick with it it Ross. I am fairly sure you will be able to run that motor on single phase with with your inverter (or capacitors!).
When you check out the wiring you should be able to find the star point fairly easily, and once the wires are separated can then just do a simple ohms check to identify the three windings. Reconfigure as delta and you will be away. Good luck. G.
CONVERSION: EMCO Compact 5 CNC Conversion
By sid8ball in forum Conversion Build LogsReplies: 1Last Post: 10-10-2019, 11:51 AM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
Emco conversion help needed
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 29-03-2014, 10:33 PM -
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
Emco Compact 5 Conversion
By Pete92 in forum Emco LathesReplies: 7Last Post: 01-10-2013, 11:31 PM
