Thread: Emco Mentor Mill conversion
05-04-2013 #25
You only effectively need 1 capacitor to run a three phase motor from a single phase, however you normally need to use a few connected in parallel to acheive the required capacitance.
Search for 'static phase convertor' if you want to know more, however you need to check the generated voltages while running to ensure the 'false' phases aren't too high/low, and the voltages will also vary depending on load.
CONVERSION: EMCO Compact 5 CNC Conversion
By sid8ball in forum Conversion Build LogsReplies: 1Last Post: 10-10-2019, 11:51 AM -
FOR SALE: Emco mill 50 cnc mill like Denford Triac
By gavztheouch in forum Items For SaleReplies: 0Last Post: 18-05-2014, 10:19 AM -
Emco conversion help needed
By Ecu-master in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 29-03-2014, 10:33 PM -
Emco mill 50 Y axis travel?
By gavztheouch in forum Emco Milling MachinesReplies: 0Last Post: 01-03-2014, 11:10 AM -
Emco Compact 5 Conversion
By Pete92 in forum Emco LathesReplies: 7Last Post: 01-10-2013, 11:31 PM
