    If your looking for advice on what drivers to fit then the first thing to do is let people know what motors are fitted. Just post the details on the motor plate & I'm sure some of the more experienced guys will be happy to suggest what drives to use & any other parts you may need.
    Software wise what have you got already & how quick do you want the machine to be working? Reason I ask is because although there is some ok free software about some of it doesn't have a lot of support & can take time to get your head round.
    You will need cad, cam & machine control software.
    Bump. I am still looking for someone with sufficient knowledge of these machines and CAD/CAM to set them up.
    I am willing to pay handsomely for each machine that is set-up. I am based in Wallasey on the Wirral.
    Cheers, much appreciated!!
    Can you get at the motors, as I said previously what drivers you fit will generally be dependant on what motors are fitted. The motors should have a plate on them with all the info, if you can post the motor details it will be easier for someone to help.
    i2i's Avatar
    there's a fair chance you could use the existing control system with a few tweaks, mach will interface with just about any step and direction system. I'm based in Cardiff, if you could get the machines here I could sort them. I could possibly call in and give them a look over, but it's a fair run up to you.
    I would probably need them here to convert though, depends on the existing control system.
    Looking at the pics, I would have thought the conversions would be pretty straight forward.
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. FOR SALE: Seig KX1 CNC Milling Machine
    By D2C in forum Items For Sale
    Last Post: 06-03-2014, 10:26 AM
  3. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  4. Vacuum bed for a milling machine
    By martin54 in forum General Discussion
    Last Post: 18-10-2012, 10:27 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
