I have the same nuts. I drilled out a chunk of mdf the diameter as the nut, slit it on one side, drilled through and used a couple of M5 bolts and M5 teenuts (captive recessed nut) to put the 'squeeze' on the delrin. 4 mounting holes in the corners allows ot to be bolted to the underside of the table/gantry/etc.
Thanks for the reply.
Would it be worth me shaving one side flat? Does the mdf hold it solid? have you got a picture of it?
Also is a moving table design better for accuracy?
