    Quote Originally Posted by martin54 View Post
    John the X & Y axis are the same size belts & gearing, the Z axis is direct via a screw but I need to remove a cover to see if it's a ballscrew or trapezoidal.
    Ten turns of the motor moved the gantry 3 inches for both X & Y axis, ten turns on the Z axis moved it down 2 inches.
    Measurements were taken using a ruler so may not be 100% accurate.
    Sorry got side tracked, the dog pissed on the carpet and then on my boots when I kicked it up the arse............
    OK X and Y ten turns to go 3" so one turn to go 0.300"
    200 step motor means each step is 300 / 200 = 0.0015" or a thou and a half per step which is a bit course.
    I reckon on a router 1/2 a thou is good enough so you want microstepping of 3 to get 1/2 thou which isn't an available step.
    If you choose 5 that gives you 0.0003" per step
    Now the Z, 10 turns = 2" so one turn = 0.200"
    0.200 / 200 give 1 thou on full steps and 1/2 a thou if you choose 2 micro steps.
    That's the maths, you may want different figures.
    John S -
  2. The Following User Says Thank You to John S For This Useful Post:
  3. #2
    Will give that a try when I get all the electrics sorted, chears John.
  1. Replies: 0
    Last Post: 11-06-2014, 12:17 PM
  2. CW5945 MicroStepping Strangeness?
    By Tenson in forum Motor Drivers & Controllers
    Last Post: 10-10-2012, 04:49 PM
  3. eBay: 3 x PM752 Microstepping Drivers
    By Iwant1 in forum Items On eBay UK
    Last Post: 24-08-2012, 11:47 PM
  4. Help please Steps and control?
    By totts in forum Motor Drivers & Controllers
    Last Post: 31-03-2012, 07:44 PM
  5. The worth of microstepping?
    By stuart576 in forum Stepper & Servo Motors
    Last Post: 18-01-2012, 09:27 PM
