Thread: MDF Panels (+ More)
Another panel attached (someone quote something!). Again millimeters. I appreciate a lot of dimensions are missing but should not prevent quoting.
09-04-2013 #2
I don't have a runnable machine, but just some friendly advice...
A quick glance at your drawings would suggest that material type, thickness and cutting depths are missing. I'd guess it's MDF going by your comments above, but it's not clear. Also the hole diameters are none standard, particularly the 8.05mm.
And above all, be patient!
09-04-2013 #3
Thanks for the post, the drawings are without most dimensions as this isn't final cad. I decided to publish them to get quotes so I can continue with the design with the knowledge of whether cnc is appropriate or whether I should design for hand operation.
The panels are in 9mm mdf, the major dimensions are there for costing of materials. The minor indicate the smallest bit size for the work. I think this should be enough for most to quote?
Thanks for the advice I'll take it into consideration if someone would like to do the job!
09-04-2013 #4
Are the centre panels complete cutouts or channels of "X" depth?
The main cost is going to be the initial setup and programming, so pricing will be highly dependent on the quantities you will require, so might be worth mentioning that as well...
09-04-2013 #5
Good points, yes the centre are cut outs with a shoulder. They are just one off but there may be a whole platform of panels which may be more appealing.
Thanks,
Tom
09-04-2013 #6
I can possibly do these.
PM me and I'll see what I can do.
RFQ: Gantry side panels
By fvfdrums in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-01-2014, 03:50 PM -
Excellent info here regarding electrical noise, ideal for panels and machine wiring.
By EddyCurrent in forum General ElectronicsReplies: 0Last Post: 19-10-2013, 12:45 PM -
RFQ: Panels cut from soft plywood
By Rockeyes in forum Projects, Jobs & RequestsReplies: 0Last Post: 12-04-2013, 04:38 AM -
RFQ: Custom corrugated sheet steel panels for home DIY project. Brake job anyone?
By Peter Dow in forum Projects, Jobs & RequestsReplies: 21Last Post: 01-06-2012, 09:31 PM
