    If I have a M10 hole thats been tapped, should I be able to put the bolt in either side or just the side it was tapped from. Never dealt with tapping until now :D
    Phil
    If you've tapped it all the way through with a plug tap, then definitely not a problem. If it's only been cut with a taper tap, then the thread may be incomplete toward the bottom of the hole, which would impede inserting the bolt from that side.
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Either way its just like a nut.. Clive
    I had to google it but it looks more like a plug. The bolt goes in fine from the tapped side but needs a spanner to turn the other way, should I just keep pushing or am I missing something?
    Look carefully at the thread. Does it look to be tapped to the same depth at both ends and check there's not a significant burr on the difficult side.
    Are you tapping these holes yourself? If you are tapping yourself do you have a set of 3 taps or are you using just one tap? If you are using a taper or second then you will need to run it almost all the way through to ensure you cut the full thread depth right through the hole.
  1. Ok PCB milled now how to drill the holes ?
    By Fivetide in forum CAD & CAM Software
    Last Post: 12-05-2013, 08:31 PM
  2. What size clamping holes ?
    Last Post: 30-12-2012, 09:10 PM
  3. RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
    By neurofen in forum Projects, Jobs & Requests
    Last Post: 25-01-2012, 04:26 PM
  4. NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
    By Simon in forum New Member Introductions
    Last Post: 26-06-2011, 10:02 AM
  5. NEW MEMBER: Silly high speed lathe.
    By rlechem in forum New Member Introductions
    Last Post: 20-07-2009, 11:50 PM
