should be ok. pay particular attention to earth star point to avoid ground loops and cable routing to keep power and control apart as far as possible. . also make sure you have RFI filter at AC input to vfd
10-04-2013 #2
Thanks for that Irving.
I'm already planning on keeping the power/control cables seperate in the control box as much as possible, but there are going to be various points in the machine where everything is going to be bundled together to get around the structure. That's why I'm opting to use 24V for any switching input, and differential for anything that can't be 24V, so noise shouldn't be an issue.
11-04-2013 #3
just got my VFD up and running and whilst going through the install section noticed that it can be installed in an enclosure but needed ventilation and a cooling fan. might be the same for yours! could be a bit toasty with the servo drives as well.
11-04-2013 #4
Cooling is always something to consider, however this cabinet is a bit larger than your typical homebrew CNC enclosure (I think I measured it at 1.2 x 0.8 x 0.3m), has an integral air to air heat exchanger, and previously housed a Heindenhain controller complete with all drives/transformers/contactors.
Domestic ring main wiring
By mekanik in forum General ElectronicsReplies: 1Last Post: 15-10-2013, 05:50 PM -
NEW MEMBER: JoeCNC, from Ireland, cabinet maker.
By JoeCNC in forum New Member IntroductionsReplies: 6Last Post: 21-09-2013, 11:24 PM -
DIY blast gun cabinet from reclaimed parts
By martin54 in forum Woodworking Project ShowcaseReplies: 9Last Post: 04-04-2013, 11:22 PM -
Layout Blue
By GTJim in forum Marketplace DiscussionReplies: 4Last Post: 09-07-2012, 10:02 PM -
Does anyone tell me the main parts of CNC Milling Machine?
By hoezap in forum General DiscussionReplies: 0Last Post: 07-11-2011, 01:25 AM
