    Its going to be a no parkin sign, about a4 size,
    This is the sort of sign/plastic
    Red with white writting.
    Think this stuff is called "traffolyte", look at UK Engraving Services laser engraving machines, service and repairs
    I've not used them so not a recommendation
    Traffolyte is a trade name in much the same way as Perspex I believe but does sound like the sort of thing you are after, try searching for engraving laminate, you should find what you are looking for from a range of different suppliers.
    If you can get the plain sheets then make your own? plumbers pvc glue or even some acetone will glue them together
    Everything you ever want for engraving.
    Engraving Materials & Supplies Webshop
    John S -
  1. Some kind of plastic needed
    By m_c in forum General Discussion
    Last Post: 08-04-2013, 12:29 PM
  2. RFQ: Small parts from FR4 plastic - help!
    By James in forum Projects, Jobs & Requests
    Last Post: 12-06-2012, 04:02 PM
  3. 2 ply plastic help
    By h4ppy-chris in forum General Discussion
    Last Post: 30-01-2011, 04:54 PM
  4. Looking for thin plastic? sheet
    Last Post: 09-09-2010, 12:32 AM
