Thread: A silly question on tapped holes
11-04-2013 #1
If I have a M10 hole thats been tapped, should I be able to put the bolt in either side or just the side it was tapped from. Never dealt with tapping until now :D
Phil
11-04-2013 #2
If you've tapped it all the way through with a plug tap, then definitely not a problem. If it's only been cut with a taper tap, then the thread may be incomplete toward the bottom of the hole, which would impede inserting the bolt from that side.
Either way its just like a nut.. Clive
11-04-2013 #4
I had to google it but it looks more like a plug. The bolt goes in fine from the tapped side but needs a spanner to turn the other way, should I just keep pushing or am I missing something?
11-04-2013 #5
11-04-2013 #6
Are you tapping these holes yourself? If you are tapping yourself do you have a set of 3 taps or are you using just one tap? If you are using a taper or second then you will need to run it almost all the way through to ensure you cut the full thread depth right through the hole.
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
What size clamping holes ?
By dudz in forum Machine DiscussionReplies: 6Last Post: 30-12-2012, 09:10 PM -
RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
By neurofen in forum Projects, Jobs & RequestsReplies: 9Last Post: 25-01-2012, 04:26 PM -
NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
By Simon in forum New Member IntroductionsReplies: 0Last Post: 26-06-2011, 10:02 AM -
NEW MEMBER: Silly high speed lathe.
By rlechem in forum New Member IntroductionsReplies: 1Last Post: 20-07-2009, 11:50 PM
