Thread: A silly question on tapped holes
I had to google it but it looks more like a plug. The bolt goes in fine from the tapped side but needs a spanner to turn the other way, should I just keep pushing or am I missing something?
11-04-2013 #2
11-04-2013 #3
Are you tapping these holes yourself? If you are tapping yourself do you have a set of 3 taps or are you using just one tap? If you are using a taper or second then you will need to run it almost all the way through to ensure you cut the full thread depth right through the hole.
Ok PCB milled now how to drill the holes ?
By Fivetide in forum CAD & CAM SoftwareReplies: 13Last Post: 12-05-2013, 08:31 PM -
What size clamping holes ?
By dudz in forum Machine DiscussionReplies: 6Last Post: 30-12-2012, 09:10 PM -
RFQ: RFQ: 3 x M5 holes drilled and tapped/ +/- 0.01mm required
By neurofen in forum Projects, Jobs & RequestsReplies: 9Last Post: 25-01-2012, 04:26 PM -
NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
By Simon in forum New Member IntroductionsReplies: 0Last Post: 26-06-2011, 10:02 AM -
NEW MEMBER: Silly high speed lathe.
By rlechem in forum New Member IntroductionsReplies: 1Last Post: 20-07-2009, 11:50 PM
