    Hi all,
    Been emailing a few companies in the UK and getting nowhere, so please PM me if you can help or know of anyone that may be able to do the work.
    I'd like some precision screws and caps made in stainless steel (316L preferred). The smallest part is approx 1.6mm x 4.3mm tapped with a M1.3x25
    Quantities from 200 upwards.
    Please get in touch if you can help
    Thanks. Mike
    see attached pic below showing the dimensions i need.
    Attachment 8758
    That looks like a real fiddly job with lots of broken taps and scrapped work pieces. Tapping a 1.3mm thread into a blind hole is a nightmare in any material. Doing it in stainless steel is certainly not helping matters. Also, you'll need to make allowances for drilling and tapping depth as I very much doubt that anyone will be able to create a flat bottomed thread like you have drawn.
    All in all, a bitch of a job and likely to be very expensive.
  3. http://www.kershaw-engineering.co.uk/
    Give this company a call and speak to Tony his work is second to none and will be right up his street. ;-)
    birchy, thanks for your input. I'm a newb with illustrator and glad it allows me to get my idea across.
    Now that you mentioned it, the other end that screws into that cap is threaded shorter so i will need to show the machinist there's allowance.
    Ad, thanks i'll contact Tony.
  1. Replies: 41
    Last Post: 08-02-2014, 11:37 PM
  2. RFQ: Require small Stainless steel buckles machining- can you help please ?
    By Gasgasbones in forum Projects, Jobs & Requests
    Last Post: 15-05-2013, 06:47 AM
  3. What kind of machine will do stainless steel or brass engraving
    By JayPunchbuggy in forum Machine Discussion
    Last Post: 13-03-2013, 10:40 PM
  4. Flexible Stainless Steel pipe that holds its shape?
    By Fivetide in forum Marketplace Discussion
    Last Post: 14-02-2013, 07:35 PM
  5. stainless steel fasteners - quality
    By dsc in forum Metalwork Discussion
    Last Post: 30-11-2012, 12:35 PM
