Thread: New CNC mill build
Hello, that's an impressive an informative first post,You are on right track as you have realised that it is best to get the correct parts to begin with, I cant answer all your questions but I'l have a stab a few.
I think you will struggle to make a single machine that can mill Ali, cut wood and do PCB work. I think you will need to consider a changeable spindle drive /motor. Ali requires low to medium speed with high rigidity. Wood needs high speed and good to high rigidity and pcbs need very high speed and super low runout. A spindle to meet all of these requirements is going to be very expensive if it existed
Depends on your bed, T slots are best as they have a good selection of clamping jigs and tools. sacrificial mdf bed means you can just screw the material to where ever needed but not to good for Ali. Pcb work is usually held by vacuum or double sided tape. Again a range of possibilities for one machine.1) Mill plate clamp? I have never milled, manually or CNC before. Do you have to clamp down the piece, I assume you have to do something to prevent it from moving, how is this generally done, what do I need to make this happen?
A router cant be controlled to easily by mach and wouldn't be any good for Ali or pcb. see above for spindle problems.2) Mill/motor? Do I use a regular router, maybe a variable speed router that I can mount on my X axis? Do I just get a regular DC motor that can be controlled via my control board? What is the best method for this?
cnc uses limits switches as end stops to prevent over travel and movable home switches to set the start points.3) End stops? In 3D printing, we use end stops to Home our axis' so we know exactly where our position is. Do I need something like this for a CNC mill?
Ali needs coolant to prevent build up on the tool and wood will need extraction or jetting to remove chips to prevent re cutting of chips and tool wear.5) water/coolant system? Is this needed for aluminum? If so, how do I go about this? I have no idea on this at all.
Good luck
13-04-2013 #2
Ross,
Thanks for your comments and feedback!
OK, let me say that my clear priority would be to mill aluminum of different sized thickness, from say 1.5mm thick to 150mm thick.
I like the idea of T-slots, I suspect a bed can be made out of aluminum extrusion, and you can make your own clamping devices using some simple t-nuts?
OK, so I think I need to figure out the following to get moving forward:
control board: Gecko vs other?
motor/spindle
design
limit switches, mechanical contact switches, other?
coolant system
If anyone has any other comments or can help me figure out what needs to be figured out, I would greatly appreciate it.
Thanks!
BUILD LOG: Build Log: 3-4 Axis Mill/Router
By IanS1 in forum DIY Router Build LogsReplies: 35Last Post: 24-10-2014, 02:12 PM -
A viable mini-ish-mill build, or a hiding to nothing..?
By Wal in forum Milling Machines, Builds & ConversionsReplies: 3Last Post: 02-07-2013, 07:33 PM -
BUILD LOG: New build - fixed gantry mill using extruded profile
By toolchimp in forum DIY Router Build LogsReplies: 3Last Post: 09-11-2012, 04:10 PM -
BUILD LOG: Quirky Turn Mill Build
By vtcnc in forum DIY Router Build LogsReplies: 8Last Post: 16-09-2012, 02:53 AM
