Thread: Unmodified Orac question
14-04-2013 #11
Thanks for the advise Swarfing. I have plans for this but it is not the right time for me to upgrade. Someone is waiting parts to make with that lathe and making profit this way then I can replace the old electronics.
14-04-2013 #12
No worries Asto, hopefully there is somebody with more experience of this machine than i have here that can help you get this working.
14-04-2013 #13
Thank you. I'll appreciate that.
15-04-2013 #14
Asto,
Have you had a look at the interlock on the key/stop button I understand you turn the key to the right press button and it will not lock down, will display man opp but will not move axis, press and hold for 3-4 seconds to energize the 2 relays before the axis will move.
Phill
15-04-2013 #15
Hi phill05 and thanks for your participation and helping effort.
Well I just followed your suggestion but there was no difference. I need to tell you though that all the operating electronics and hardware are not tightened/screwed on the lathe. It is all on the bench where I will instantly notice when the change comes. I believe might have been a wire left unconnected or disconnected I am not sure which one is the right word here. Please correct me. For example I have omitted signal wires coming from the perforated speedometer disc, those coming from turret indexing sensor, as well as those directed to power chuck electropneumatic solenoid, those directed to Parajust VFD pot and stop/restart inputs.
When the machine's X-axis was losing direction 2 weeks ago, searching for faulty wire connections I found that the X-stepper was not wired correctly. When I restored this, both axes worked perfectly responding to sudden commands. Both motors now retain good holding torque.
Last night I replaced the 30 year old stepper with the one seen in the attached image...With the StepSyn steppers this Orac worked non stop for 5 years 4 to 6 hours a day...
regards
AstoLast edited by asto; 15-04-2013 at 06:42 PM.
23-04-2013 #16
denford orac tail stock dimensions
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 3Last Post: 24-11-2013, 10:42 PM -
Help needed connecting IMO JAGUAR VFD to Orac
By asto in forum Spindles & Drive MotorsReplies: 0Last Post: 09-04-2013, 08:05 PM -
x-axis on Orac losing direction
By asto in forum Motor Drivers & ControllersReplies: 3Last Post: 29-03-2013, 01:22 AM -
RFQ: Spindle for a Denford ORAC
By rnr107 in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2012, 05:20 PM -
Orac lathe
By phill05 in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 13-07-2012, 09:05 PM
