Thread: New Autoleveling PCB software
What a musical machine, if it was mine I'd be forever trying to make it play Jingle Bells
14-04-2013 #2
Noisy isn't it. and slow.
17-06-2013 #3
The Autoleveller software is now available at www.autoleveller.co.uk so please feel free to download and try it.
There are many changes planned but any feedback or questions are very welcome, good or bad.
Most of the instructions are on the page but if there is anything confusing, or anything not explained, please let me know either in the comments section at the bottom of the page or here.
enjoy,
The Following User Says Thank You to Daedelus For This Useful Post:
17-06-2013 #4
Daedelus: Does this now mean that my NDA is now void
"If first you don't succeed, redefine success"
17-06-2013 #5
Great work! I actually bought cnc-usb software as Andrej (the author) agreed to integrate Z probing to help with pcb milling etc..
A few points to note when Z probing...
In case it's not obvious, you need a very accurate Z axis when using this probing technique ...especially if you are probing a lot across the stock - because any Z backlash will seriously affect the measurements (& more importantly - the outcome!) My small CNC machine only uses threaded rod & modest nuts...I got poor results initially due to too many probe points in conjunction with backlash errors - best to probe as little as you think you can get away with.
It's still a good idea to level your bed.... pcb milling is all about minimizing the errors (cause when your V cutting tip is only 0.2mm, every little bit of Z accuracy counts)
Be sure to probe to the g code extremeties...most 'divergences from the mean' are due to clamping at the edges (& the inevitable bowing up...albeit small - in the centre)Last edited by HankMcSpank; 17-06-2013 at 03:17 PM.
17-06-2013 #6
Thanks Hank, the backlash info is worth noting.
I consider myself a hobbyist when it comes to CNC and machining in general (my background is in software engineering / development) however, my machine does include anti-backlash nuts and I have no idea what the probing accuracy would be like without them. From what you say, it would not be that good. In this situation, would it help to reduce the Z (probing) feed-rate to improve accuracy? Also, yes, it would be a good idea to level the bed as you say.Last edited by Daedelus; 17-06-2013 at 06:21 PM.
17-06-2013 #7
Mad Professor has been aiding me a lot with running the software and testing with Mach 3. I am aware that he used the software when etching a design on a metal box lid. This shows that Autoleveller is not the sole domain of PCB designs.
Anyway, thanks Prof. Your help is very much appreciated.
17-06-2013 #8
Here is one of the cases I did some engraving on that I used Daedelus Autoleveling software with.
!!! Warning !!! you may want to turn down your speakers before starting the below video.
The half cases are extruded aluminium and are anodized black, and the surface is anything but flat.Last edited by Mad Professor; 17-06-2013 at 06:47 PM.
17-06-2013 #9
Prof. This is a great video to show the versatility of Autoleveller (i.e. not just for PCB's). Would you mind if I link to it from the web page?
software
By rainboweyes in forum Computer SoftwareReplies: 4Last Post: 09-02-2013, 11:59 AM -
Newbie. Questions about design software and machine control software
By MTech in forum Computer SoftwareReplies: 2Last Post: 11-12-2012, 12:58 PM -
best software
By k2me in forum CAD & CAM SoftwareReplies: 10Last Post: 23-06-2011, 02:55 PM -
Which Software
By Ricardoco in forum CAD & CAM SoftwareReplies: 41Last Post: 12-01-2011, 04:43 PM -
What software ??
By Kammo1 in forum Computer SoftwareReplies: 11Last Post: 07-09-2007, 01:46 PM
