Thank you Jay,
Looks like I have a lot to think about....what I did like from the 6040 was that the spindle is water cooled which I think may be a bonus with the amount of work I can see it doing.
Where did you find out what parts to replace and where did you buy them from?
Thanks for your input and help
Phillip
15-04-2013 #2
Hi Phillip,
Didn't replace any parts, except for the IEC power cables. It came with euro ones, that wouldn't have connected the earth. Apart from that, I put it together as sent and it worked. No mods were needed.
However, I didn't like how the inverter was connected, and manually controlled. So I rewired the inverter to take its power from the main controller through the pump switch. This saved me from powering the inverter from the wall switch. I then wired the cooling pump to switch on only when the spindle was turning using the inverter's built in relay. Finally, I got a cheap RS-232 to RS-485 converter and used that to connect the pc to inverter. This, with a MACH3 add in driver, let me completely control the spindle on the PC.
So, I didn't have to mod anything, I just improved the set up by doing so.
Some day, I would like to replace the controller, so that I can drive the steppers with more than 24volts. This would give greater speed or torque if I need it... But it can wait.
I should write up the details rewiring I did, just haven't had a chance.
Hope this helps, and good luck with whatever you decide to get.
Cheers,
JayLast edited by JayPunchbuggy; 15-04-2013 at 10:11 PM.
16-04-2013 #3
Hi Jay,
I think from all I have read I will be going down the Eagle 3 route just for ease and also backup.
Thank you so much for all your help though it really has pointed me in what I think is the right direction.
Phillip
16-04-2013 #4
No problem, Phillip.
I wasn't trying to stear you in one direction or the other. Glad you found my info useful in coming to a decision. I very nearly went for an Eagle...
I definately think that the Vectric software is very good. I am using VCarvePro and love it. Cut2D will probably be good as well.
Let us know how it goes!
JayLast edited by JayPunchbuggy; 16-04-2013 at 09:07 AM.
16-04-2013 #5
I looked at both vcarve pro & cut2d & both looked to be very user friendly which when you hate having to learn new software as much as I do is a good selling point. vcarve pro is obviously a much more complete package & if I had needed some sort of cad software then that would probably have been my choice. As it is I already had & was familiar with other vector based software so only really needed something to generate the toolpaths.
The other thing I liked about vetric was that having bought cut2d if in the future I decided I wanted to upgrade to say vcarve pro I got a discount that was almost equal to what I paid for cut2d.
16-04-2013 #6
Main differences in VCP and Cut 2D is VCP has more features including V carving, nesting and the ability to use multiple tools.
It also had more CAD features but neither in my opinion have what i call decent CAD capabilities.
That in itself is no problem as there are loads of good and free 2D cad programs out there.John S -
16-04-2013 #7
John are there any features that VCP has that make it worth having over Cut2D if nesting isn't a feature that bothers you & you don't have an ATC ?
I've got software for producing 2D vectors, not a CAD package but arty farty software as you called it lol. I opted for cut2d as all I thought I would really need is something to generate the toolpaths. Still all new to me so just wondering if I was missing something.
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
