Hi Phillip,
Didn't replace any parts, except for the IEC power cables. It came with euro ones, that wouldn't have connected the earth. Apart from that, I put it together as sent and it worked. No mods were needed.
However, I didn't like how the inverter was connected, and manually controlled. So I rewired the inverter to take its power from the main controller through the pump switch. This saved me from powering the inverter from the wall switch. I then wired the cooling pump to switch on only when the spindle was turning using the inverter's built in relay. Finally, I got a cheap RS-232 to RS-485 converter and used that to connect the pc to inverter. This, with a MACH3 add in driver, let me completely control the spindle on the PC.
So, I didn't have to mod anything, I just improved the set up by doing so.
Some day, I would like to replace the controller, so that I can drive the steppers with more than 24volts. This would give greater speed or torque if I need it... But it can wait.
I should write up the details rewiring I did, just haven't had a chance.
Hope this helps, and good luck with whatever you decide to get.
Cheers,
JayLast edited by JayPunchbuggy; 15-04-2013 at 10:11 PM.
16-04-2013 #2
Hi Jay,
I think from all I have read I will be going down the Eagle 3 route just for ease and also backup.
Thank you so much for all your help though it really has pointed me in what I think is the right direction.
Phillip
16-04-2013 #3
No problem, Phillip.
I wasn't trying to stear you in one direction or the other. Glad you found my info useful in coming to a decision. I very nearly went for an Eagle...
I definately think that the Vectric software is very good. I am using VCarvePro and love it. Cut2D will probably be good as well.
Let us know how it goes!
JayLast edited by JayPunchbuggy; 16-04-2013 at 09:07 AM.
16-04-2013 #4
I looked at both vcarve pro & cut2d & both looked to be very user friendly which when you hate having to learn new software as much as I do is a good selling point. vcarve pro is obviously a much more complete package & if I had needed some sort of cad software then that would probably have been my choice. As it is I already had & was familiar with other vector based software so only really needed something to generate the toolpaths.
The other thing I liked about vetric was that having bought cut2d if in the future I decided I wanted to upgrade to say vcarve pro I got a discount that was almost equal to what I paid for cut2d.
16-04-2013 #5
Main differences in VCP and Cut 2D is VCP has more features including V carving, nesting and the ability to use multiple tools.
It also had more CAD features but neither in my opinion have what i call decent CAD capabilities.
That in itself is no problem as there are loads of good and free 2D cad programs out there.John S -
16-04-2013 #6
John are there any features that VCP has that make it worth having over Cut2D if nesting isn't a feature that bothers you & you don't have an ATC ?
I've got software for producing 2D vectors, not a CAD package but arty farty software as you called it lol. I opted for cut2d as all I thought I would really need is something to generate the toolpaths. Still all new to me so just wondering if I was missing something.
16-04-2013 #7
Main thing is the vee carving.
Cut2D leaves radii in the corners equal to 1/2 the cutter diameter.
VCP uses a vee tool and lifts it in the corners to make it appear to be sharp cornered.
If all you are doing are signs for big birds bedroom door cur 2D is fine.
If you want small detailed work you need VCP.John S -
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
