16-04-2013 #26
Main thing is the vee carving.
Cut2D leaves radii in the corners equal to 1/2 the cutter diameter.
VCP uses a vee tool and lifts it in the corners to make it appear to be sharp cornered.
If all you are doing are signs for big birds bedroom door cur 2D is fine.
If you want small detailed work you need VCP.John S -
Milling Machine Advice
By Washout in forum Milling Machines, Builds & ConversionsReplies: 28Last Post: 29-07-2014, 10:03 AM -
Need advice for a new machine?
By az786again in forum General DiscussionReplies: 7Last Post: 05-03-2014, 02:04 PM -
Advice about a sentence concerning CNC Machine!!!
By hoezap in forum General DiscussionReplies: 5Last Post: 09-11-2011, 02:25 AM -
cnc machine buyers advice
By wyndham in forum Marketplace DiscussionReplies: 0Last Post: 29-06-2011, 06:52 PM -
Machine Buying advice
By jrob3rts in forum Marketplace DiscussionReplies: 0Last Post: 17-09-2010, 04:59 PM
