    Joe's Avatar
    Lives in Shropshire, United Kingdom. Last Activity: 28-01-2020 Has been a member for 9-10 years. Has a total post count of 31. Received thanks 1 times, giving thanks to others 1 times.
    Thanks for your input
    I have now changed round the Y axis plate as you said, this is one of those little things that will make putting the whole thing together much easier.
    Ross what exactly do you mean by make the Y axis wider? doesn't this mean that the distance between the cutting tool and the back of the Y axis will be further?
    As for the 2:1 belts, I had considered this but I wasn't sure if they would flex to much as in my old machine the belts stretched quite a lot under load. I was wondering what your experience of this was. And could I ask what sort of feet rate is possible from a 5mm pitch screw using 72V NEMA 23 drivers.
    Yes I considered making the gantry sides much smaller but I was doing it this way so that the whole frame that the machine sits on could be fly cut flat so that I don't have any issues with the bed not being flat or to far off flat. but your right this would make the whole machine stiffer. But thinking about it just now as long as the surface that the rails sit on are flat compered to each other then the the machine could level its bed and it should then be fairly flat.
    I will change the design slightly and put up a few more pictures
    Thanks for all your help everyone
  1. Vertical router design
    By EddyCurrent in forum Gantry/Router Machines & Building
    Last Post: 29-03-2014, 10:43 PM
  2. Router design thoughts
    By m_c in forum Gantry/Router Machines & Building
    Last Post: 11-09-2012, 07:06 PM
  3. Design help etc required with DIY CNC Router Design / Build
  4. Need 6' x 4' bed, 4 axis router design.. Help..!
  5. Base design for new router
    By cncgreg in forum Gantry/Router Machines & Building
    Last Post: 31-08-2010, 03:35 PM
