Thread: My second router design
03-05-2013 #14
Right I have now changed the design quite a bit
The gantry is now much smaller and I have lifted the sides of the machine up to compensate. The main of the frame will be from box section steel, either 100 x 50 or 50 x 50 with the thickest wall I can get. I will try to weld it using clamps to keep it square and flat the best I can but it will then be fly cut to make sure that the top face is accurate and then the machine can face its base plate to ensure that is flat.
My plan is to have a second false floor that can be bolted into the frame which will be around 100 mm thick for machining parts which require less z travel, this should then make the machine much stiffer as the z axis will not be as far out.
As for driving the ballscrews with belts I am going to stay with direct drive at the moment to save some cost, but I am sure for what I am doing the slower rapid rates will not be to much of a problem.
If anyone else has any suggestions please let me know
Vertical router design
By EddyCurrent in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 29-03-2014, 10:43 PM -
Router design thoughts
By m_c in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 11-09-2012, 07:06 PM -
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 12Last Post: 21-10-2011, 04:50 PM -
Need 6' x 4' bed, 4 axis router design.. Help..!
By fasteddy in forum Gantry/Router Machines & BuildingReplies: 29Last Post: 17-09-2010, 12:56 PM -
Base design for new router
By cncgreg in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 31-08-2010, 03:35 PM
