Page 2 of 2 FirstFirst 12
    John could we get a bit more real life usage of the hydrovane 5 series.
    I've been looking on ebay for some time now and they do come up often for around £300, which I don't mind paying, but when I read the specs of the 501, it only produces 4.2 cfm FAD. Seems crap against say a £300 secondhand 150ltr Sealey/Abac/Clarke with 14cfm. Would the 501 easily allow for some spray painting, blasting, sanding. Could it even be used for blowing chips away.
    Feel like I have to look at a big 3 phase hydorvanes to get any where near descent Ccfm. But then these are a huge step up, with ratings of 20+ cfm.
    Are the hydrovane and regular compressor cfm's not comparable?
    Cheers Adil
  2. Lol John how did you know i was talking about you :-p
    Hope this isn't classed as a hijack it is about air compressors lol.
    Read what John was saying about compressor outputs & that he had said to look out for hydrovane series 5 units but I'm not sure if something that size would do for the blast cabinet, the 5 series from what I can see chucks out about 5 cfm & the blast cabinet needs a minimum of 7 cfm @ 80 psi, more would be better.
    Realise from Johns post that those figures might not mean a lot so needing a bit of help with what might be suitable without having to take out a loan.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I've got the small clarke blast cabinet, which supposedly requires 10cfm at 80-100psi, however my 3hp cheapo keeps up with it reasonably well.
    Constant blasting does mean the compressor never stops, so I do stop occasionally to give it a rest, but it's not caused any issues so far.
    I suspect a Hydrovane 5 might be a bit on the small size, however you could always couple it into your existing compressor, and run them side by side.
    I was actually hoping to get away from the cheapo compressors because of the noise they make, even with a pair of ear defenders on it's a bit loud lol. Had thought about running 2 machines together & haven't entirely written the idea off but I'm not in a huge rush to get it going at the moment. Will kind of manage to do my wheels with it even if it does take a lot longer than it should & glass etching will probably need a lot less pressure although I haven't really researched that at the moment.
    Pity I don't have a 3 phase supply in the unit as you seem to be able to pick up used screw compressors at a reasonable price although I haven't looked at the running costs of them.
    Martin you can hook a compressor up to a vfd so they are not out of the question.
  1. FOR SALE: Pssst. Compressor - grab a bargain!
    By Wal in forum Items For Sale
    Last Post: 15-03-2014, 12:32 AM
  2. Compressor specification for alu chip blower
    By Saracen in forum Machine Discussion
    Last Post: 12-01-2013, 09:17 PM
  3. Has my air compressor died?
    By Jonathan in forum General Discussion
    Last Post: 15-10-2012, 12:08 AM
  4. Which air compressor?
    By newtoid1986 in forum General Discussion
    Last Post: 12-12-2011, 04:07 PM
  5. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 11:33 AM
