    What to look for in an air compressor.
    Air.......
    They come up much cheaper than that, just don't look for one that looks like you can eat your dinner off. A bottle of sugar soap and a bit of elbow grease is much cheaper than a noisy cheap one take my word for it.
    air compressor | eBay
    First one i came to and you can get them cheaper like i say. Don't worry about 3 phase either as you can run it with a VFD
    If you go for a Hydrovane go for a 5 series, plenty big enough and many are on single phase.Search on ebay for hydrovane 501
    Don't buy the tripod mounted ones, get the tank mounted.
    They are different, the tripod mounted ones unload the compressor when pressure is reached so the motor runs all the while.
    The tank mounted units have pressure switches.
    I run two 5 series side by side but only run one at a time however both tanks are coupled so I have plenty of air.
    John S -
    John could we get a bit more real life usage of the hydrovane 5 series.
    I've been looking on ebay for some time now and they do come up often for around £300, which I don't mind paying, but when I read the specs of the 501, it only produces 4.2 cfm FAD. Seems crap against say a £300 secondhand 150ltr Sealey/Abac/Clarke with 14cfm. Would the 501 easily allow for some spray painting, blasting, sanding. Could it even be used for blowing chips away.
    Feel like I have to look at a big 3 phase hydorvanes to get any where near descent Ccfm. But then these are a huge step up, with ratings of 20+ cfm.
    Are the hydrovane and regular compressor cfm's not comparable?
    Cheers Adil
    You have basically answerd your own question when you state 4.2cfm FAD which means Free Air delivery. because they don't have a swept volume like a piston compressor they have to state what they put out.
    CFM means sod all, CFM is the swept volume x revs in one minute and doesn't take into account valves opening and closing which is when the proper work is done.
    Read this.
    The "power" of an air compressor
    John S -
  7. The Following User Says Thank You to John S For This Useful Post:
  8. #7
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    1234567890
  1. FOR SALE: Pssst. Compressor - grab a bargain!
    By Wal in forum Items For Sale
    Last Post: 15-03-2014, 12:32 AM
  2. Compressor specification for alu chip blower
    By Saracen in forum Machine Discussion
    Last Post: 12-01-2013, 09:17 PM
  3. Has my air compressor died?
    By Jonathan in forum General Discussion
    Last Post: 15-10-2012, 12:08 AM
  4. Which air compressor?
    By newtoid1986 in forum General Discussion
    Last Post: 12-12-2011, 04:07 PM
  5. Air compressor - faulty, how do I get the motor out?!
    Last Post: 26-10-2009, 11:33 AM
