Thread: From Chinese to Taffynese
Ok, hard to tell from the pics but I suspect you're a little confused. What you're calling the PSU (the round jobby) is just the transformer - it is only one component of the PSU. It has, I'd guess from the picture, two 18volt AC secondary windings. The primary is the 240v winding (suggest you read up on transformers on wikipedia). The lower board rectifies the 18volt AC to give approx 24v DC. You will need to connect this to the 3 new drivers. The easiest way would be to use a bit of 10amp 'chocolate block' connector strip to act as a splitter. I'd do you a drawing but can't on my phone.
Its not clear from the pic what the spindle connections are so I'm not going to comment right now, but PWM (pulse width modulation) suggests that lower board also has the spindle speed controller on it. Can you post a close up of the lower board only.Last edited by irving2008; 08-07-2013 at 05:21 AM.
08-07-2013 #2
OK had a chance to do a little more research. There are various versions of this board but its possible that it takes the 240v AC and rectifies this to provide the DC for the spindle so be careful how you relocate this into the new box as there could be 340v DC on that board.
Personally I'd get a new 36v power supply for the steppers as the new drivers can handle it and you'd get speed/torque benefits.
09-07-2013 #3
My thoughts exactly (replacement that is) to be honest.
As I said, I've worked out where the X,Y,Z etc go and the power but still don't quite understand how to wire up the spindle, does that require a seperate PSU as the ebay sellers are as useless as tits on a bull when it comes to answering questions, and how does one work out which wire from let's say X goes in to where on the steppers. I've tried I think every combination in to A+ A- B+ B- but can't get movement so frustration is creepin' in now
Carl
Cardiff City Supporter ~ Real Sporting de Gijon Supporter ~ Vintage Synthesizer Collector
La gente dice que tu vida esta planeado, me gustaría encontrarse con el jefe de planificacion para que yo pudiera darle un punetazo en la cara!
Chinese Spindles
By Ricardoco in forum Generic Chinese SpindlesReplies: 123Last Post: 05-12-2016, 12:16 AM -
WANTED: 2.2 KW Chinese Spindle
By Chaz in forum Items WantedReplies: 2Last Post: 17-06-2013, 10:03 AM -
WANTED: Chinese 1.5kw spindle/vfd
By Philly in forum Items WantedReplies: 5Last Post: 10-02-2013, 11:44 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM
