21-04-2013 #2
Welcome Bearingstation I was wondering if you could shed any light on the answer to life the universe and everything?
Alternatively do you recommend gluing aluminium pulley to the shafts of stepper motors with strong loctite?Last edited by gavztheouch; 21-04-2013 at 11:33 AM.
CNC routing and prototyping services www.cncscotland.co.uk
ADD ME ON FACEBOOKS
22-04-2013 #3
Hello. If you were going to use an adhesive i would recommend Bondloc B415X20GRM which is the same as loctite only cheaper. Normally you would also have a grub screw with the shaft nipped to locate the pulley to ensure a secure grip. The only other thing to consider is the speed and temperature which could have an effect on any bond. I have attached a data sheet or linked anyway for you to check out the adhesive Bondloc manufacturer of Industrial Adhesives and Sealants
Meaning of life easy. Its 42.
Phil
Bearing fit problem
By paulus.v in forum Linear & Rotary MotionReplies: 7Last Post: 09-10-2013, 09:54 AM -
NEW MEMBER: Hi - I'm part of the Bearing Station team...
By Mark Proctor in forum New Member IntroductionsReplies: 4Last Post: 19-04-2013, 09:07 AM -
Bearing Blocks
By GTJim in forum Rails, Guideways & BearingsReplies: 1Last Post: 15-01-2013, 07:18 PM -
FOR SALE: Weller soldering station and irons - consider any offers....
By Jimmybristol in forum Items For SaleReplies: 2Last Post: 01-06-2011, 10:42 PM -
BUILD LOG: Router Station
By scotsman in forum DIY Router Build LogsReplies: 6Last Post: 13-03-2011, 08:10 AM
