24-04-2013 #5
This is what should happen. When your drive is disabled it is NOT holding (RTFM) So far so good - leave enable disconnected.
This is also as it should be. If you RTFM it says steps occur on the RISING edge so holding it to GND will do nothing (except that when you remove it from GND - IF it has a pull up resistor it should step ONCE.
What is the step pulse MARK and SPACE from your Arduino? The timing sheet on page A-3 is a bit crap in that it gives the step clk width to the LOW and yet it says previously that it steps on the rising edge. Anyway if you arrange your Arduino to give a square wave of equal mark, space at around 50Hz it would be reasonable.
Make sure as well as your Arduino to driver pin6 step wire you've also connected the arduino GND also.
If that doesn't do it you may want to post your Arduino sketch for checking.
IanLast edited by stirling; 24-04-2013 at 03:59 PM.
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Geck 540 motor drivers??
By gerrymoore in forum Motor Drivers & ControllersReplies: 18Last Post: 22-09-2013, 08:23 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
wiring the drivers to the BOB
By deannos in forum Motor Drivers & ControllersReplies: 5Last Post: 26-11-2011, 07:05 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM
