24-04-2013 #7
I would try connecting enable pin 11 to high as I beleive that leaving floating can cause it to be unstable, especially if you haven't got all the grounds connected in star. at least if you make it high then the drive will be enabled and you can cross it off the list.
Have you got a logic probe? these are good for testing logic status and detecting floating and ground issues
This is also as it should be. If you RTFM it says steps occur on the RISING edge so holding it to GND will do nothing (except that when you remove it from GND - IF it has a pull up resistor it should step ONCE.
Ok pulse it with 5v then. If it doesn't work by pulsing the step pin I doubt that it is the Arduino, would indicate a motor/ driver issue. Have you got any other motor or drives, would help establish if it is a hardware/wiring problem or software.Last edited by Ross77; 24-04-2013 at 07:29 PM.
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Geck 540 motor drivers??
By gerrymoore in forum Motor Drivers & ControllersReplies: 18Last Post: 22-09-2013, 08:23 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
wiring the drivers to the BOB
By deannos in forum Motor Drivers & ControllersReplies: 5Last Post: 26-11-2011, 07:05 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM
