25-04-2013 #9
Well I have had a poke around for 20 minutes this morning. And I couldn't really tell you what I did but It did start up and chugged a couple of steps.... then stopped again
I have tested the arduino output and that is fine.
It started up after i put the direction pin to ground unless I accidentally tapped another pin, I will have another read of the datasheet. It seemed as though it had remembered a sequence of steps / directions and then after getting the nod did them then promptly stopped again. I tried to re-create what happened but had to leave for work!
Guess that's progress :D
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Geck 540 motor drivers??
By gerrymoore in forum Motor Drivers & ControllersReplies: 18Last Post: 22-09-2013, 08:23 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
wiring the drivers to the BOB
By deannos in forum Motor Drivers & ControllersReplies: 5Last Post: 26-11-2011, 07:05 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM
