25-04-2013 #1Yes i think that reading THE DATA SHEET is the best course of action.I will have another read of the datasheet.
If you do get stuck you could see if there is a forum for CNC related issues and ask someone for help
25-04-2013 #2
You might want to also double check you have the motor phases connected correctly.
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Geck 540 motor drivers??
By gerrymoore in forum Motor Drivers & ControllersReplies: 18Last Post: 22-09-2013, 08:23 AM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
wiring the drivers to the BOB
By deannos in forum Motor Drivers & ControllersReplies: 5Last Post: 26-11-2011, 07:05 PM -
Help wiring M60STH88-3008DF Steppers Motors to 752 Drivers
By Mad Professor in forum Stepper & Servo MotorsReplies: 12Last Post: 01-09-2011, 10:09 AM
