Hank if it was me i would be tempted to buy 4mm flat bar and rip down the length at your 1.6mm thickness on a bandsaw. You could then stack and cut multiples to the length you need? I'm sure you bog standard metal supplier could do that for you rather than going to fabricators and such like?
26-04-2013 #2
Hi Hank,
I would suggest that you should be able to obtain 14g x 4mm flat wire in stainless, which would probably be better suited to your application. You'd then only have to worry about the length, but a guillotine would make a neat job of the ends. If you did a detailed google search I'm sure your find a wire supplier. I think they might use this type of wire within the craft / jewellery trade, maybe worth going down that route?
26-04-2013 #3It's a 'blade' for the inside (pole piece) of a guitar blade pickup,
For looks I think ground would be best, but then again gutiarists being the funny lot hey are you will probably have to have the option of chromed, black chrome, polished steel, ground and nasty gold plated.
I've cut 1.5mm in a guillotine before, not sure I would want to do it a 1000 times tho, if its 20 or so for R&D then no prob, also leave shear marks on the edge so would still need finnishing. since its for a production run you will probably be best getting a quote from a fabrication company.
26-04-2013 #4
Good spot...perhaps I could sell to banjoists or maybe back to the drawing board ;-)
Joking apart, that's just the blade for EADG...there's a small gap of 1mm & then B & E get their own blade/treatment (I didn't want to cloud the issue, hence only showing the EADG blade!)
I just don't think I could get the accuracy for a 1.6mm width cut ...& all places I've been in touch with (admittedly only Ebay metal suppliers), can't seem to cope with anything that can't be guillotined (anything less than about 13mm cut width seems to get a "No can do, guv" type response)
Alas, stainless is no good for this application (stainless isn't very magnetic, and the material I need to use must be very magnetic)
I'd pondered one of these....
http://www.arceurotrade.co.uk/Catalo...ng-and-Bending (I can get 1.6mm steel cut 33mm wide) ...then I'd only have the 4mm strip to cut - but I reckon a 4mm strip will curl/deform (& then there's a gripping square problem as it's beinf fed in)
They tout this precision shear as having little deformation....
http://www.monstermarketplace.com/es...p-metal-cutter but only available Stateside & it'll cost a pretty penny for them to put it in an oversize jiiffy bag & post it to me!Last edited by HankMcSpank; 26-04-2013 at 08:51 PM.
26-04-2013 #5
I'd think laser or waterjet will give the cleanest 'as cut' edge with minimal distortion, however I'd think you'd really need to get them ground after that to get a clean edge.
However I'd guess laser/waterjet will be pretty expensive unless you go for a large batch. Grinding would involve somebody with a surface grinder and small vice.
27-04-2013 #6
28-04-2013 #7
Magnetic chucks are only any good for items with large flat surfaces, not holding a small flat bit on edge.
A small vice mounted on the magnetic chuck, with the metal spaced appropriately would work fine.
Milling mild steel
By dudz in forum Machine DiscussionReplies: 33Last Post: 16-02-2014, 02:31 PM -
RFQ: Several mild steel parts
By dudz in forum Projects, Jobs & RequestsReplies: 6Last Post: 26-08-2013, 11:37 AM -
Cutting 1.6mm mild steel with a CNC machine?
By HankMcSpank in forum Machine DiscussionReplies: 4Last Post: 01-05-2012, 09:56 PM -
Homemade desktop CNC - cutting 0.8mm mild steel out the question?
By HankMcSpank in forum General DiscussionReplies: 7Last Post: 16-04-2010, 09:37 AM -
Where to get 1/8" sheet mild steel laser/water jet cut?
By HankMcSpank in forum Marketplace DiscussionReplies: 28Last Post: 10-02-2010, 01:28 AM
